1986 YFM 80
Old May 22, 2008 | 10:55 AM
kjla0504's Avatar
Default 1986 YFM 80
I just rebuilt the carb, it hasn't run in about two years.
I hooked up the charger, and it turned over no problem. I sprayed a little starting fluid in the carb, and now it clicks once or twice and nothing. It is dead.
WHY? ANY SUGGESTIONS?
Old May 22, 2008 | 11:08 AM
ATV_MAN's Avatar
Default 1986 YFM 80
You say it clicks now after you charged it, seems like the battery wont hold a charge. Can you boost the battery and turn it over, will it start then? More details please.
Old May 22, 2008 | 11:11 AM
kjla0504's Avatar
Default 1986 YFM 80
I hooked up a jump pack, and the motor was turning over but not starting. I introduced a little spray of starting fluid, and the motor turned over once, and now does nothing. almost sounds like the starter engages, and than it just clicks. I almost thought it was vapor locked, but its not.
Old May 22, 2008 | 11:16 AM
ATV_MAN's Avatar
Default 1986 YFM 80
Is the kill switch off? did you check for spark? is the fuel line clean? there are many things to check for. Im not trying to discourage but is the carb set up properly?
Old May 22, 2008 | 11:30 AM
kjla0504's Avatar
Default 1986 YFM 80
It's all set, I'm thinkin possibly the starter solenoid may just be finicky and after sitting for so long. Maybe just coincidence w/ the starter fluid???
Old May 23, 2008 | 11:54 AM
ctateusa1's Avatar
Default 1986 YFM 80
I think your on the right track, my older 250 moto 4 does the same thing.
1986Vmax540
Jul 9, 2021 09:53 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
Sep 1, 2015 11:59 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
