gear ratio to cc's
Old May 22, 2008 | 08:03 PM
shea_davis1214's Avatar
Default gear ratio to cc's
i was wanting to how the ratio of many cc's it takes to equal 1 hp.
Old May 22, 2008 | 10:49 PM
Doctorturbo's Avatar
GOT BOOST!
No such thing.
Old May 23, 2008 | 12:01 AM
TomM's Avatar
Both do exist but there is no exact ratio. CC's is just one of many variables that determine HP
Old May 23, 2008 | 11:52 AM
COTU's Avatar
Torque x RPMs = Horsepower
CC's can give you a "rough" estimate of torque on a NA 4 stroke, but there are factors can sway the number up or down some. Many factors determine the RPM range of an engine and that can vary greatly.
There are some very small model (radio controlled car) engines that spin 30,000 RPMs that claim 1 HP and you can compare that to a 1 hp "Briggs" style engine and you get the idea that CC's alone can not be used to determine HP.
Old May 23, 2008 | 02:36 PM
headpressure's Avatar
Horsepower without torque is almost useless.
So many factors are involved that it is nearly impossible to use displacement to determine horsepower.
You have to consider the engine design (stroke vs bore), the efficiency of the chamber to get air/fuel (2,3,4 & 5 valve engines), combustion chamber design, ignition timing and fuel type. Even items like force feeding with turbos to increase the air/fuel charge in the chamber will change everything.
One thing you can be sure of is that with everything equal in design, more displacement will produce more power.
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
