Honda Mechanic need help...
Old May 24, 2008 | 11:26 AM
jokout's Avatar
Default Honda Mechanic need help...
Buddy of mine with a Rancher 420 wants to move his rad. up to the front rake but has concerns about the resevoir, does he also need to relocate the resevoir or will it work fine in it's present location?
Old May 24, 2008 | 05:34 PM
wilber15's Avatar
I've never moved a radiator on a wheeler, but if you look at cars the reservoir is always higher then the radiator. this allows for pressure to bleed into the degas bottle when hot. as the engine cools, the coolant depressurizes and the fluid flows back into the radiator. If you move the radiator higher, but leave the res low(in my thinking) the fluid will flow out of the radiator and fill the bottle?? I've never done it, so it's just a guess.....
Old May 25, 2008 | 03:56 AM
jokout's Avatar
exactly my thinking, but it seems that only a few that move the rad. move the bottle so we where a bit puzzled by this
Old May 26, 2008 | 06:04 PM
Nemesys67's Avatar
Just curious as to why you would want to move it.
Old May 26, 2008 | 06:17 PM
jokout's Avatar
he is metal, and mud is the magnet! If you get my meaning! LOL!
He tends to get the rad screen plugged up with mud then overheats...
Old May 26, 2008 | 06:20 PM
Nemesys67's Avatar
lol gotcha. Well..good luck with the move. Post some pics when done...I would like to see what it looks like unless its nothing special.
Old May 26, 2008 | 07:47 PM
HondaMechanic's Avatar
I'm not sure if the reserve tank must be moved up .. Other Honda models (street bikes) have the reserve/overflow tank below level with the rad , GoldWings , CBR's etc. have the tank MUCH lower than the rad , I believe the only reason Honda has the reserve tank high is to keep it away from stones/sticks etc ..
Old May 27, 2008 | 11:00 AM
wlvrn's Avatar
heres the pics. im not sure its going to stay there yet. it works good im just not sure if i like it there yet [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 27, 2008 | 11:05 AM
wlvrn's Avatar
im thinking about making a platform to put on the front rack and then laying the radiator down so the fan is on top and using the resevoir to add the fluides. im not sure if that will work or not yet. any thoughts?
greg74
Sep 10, 2019 03:03 PM
Aug 5, 2015 02:10 AM
DeFox500
Jul 26, 2015 06:32 PM
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
