95 Kodiak problem
Old May 25, 2008 | 01:15 PM
intimidtr3's Avatar
Default 95 Kodiak problem
I got a 95 Kodiak 400 the other day has been sitting for 2 years.Guy says it ran when he parked it so i drained fuel,cleaned carb and put ne plug and battery in it.Nothing,will not start.I think the compression is low(going to test today)what should it be?If it is that how hard is it to put a new piston and ring in it.Also,what is the plug gap supposed to be?Thanks for any help.
Old May 26, 2008 | 12:22 AM
91Warrior357's Avatar
any spark? check wires ur psi shud be 100+ i thnk but nt sure bout dat bike piston is easy just take ur time
Old May 26, 2008 | 11:18 AM
intimidtr3's Avatar
Yes,it has spark.I will check the compression.
Old May 29, 2008 | 04:43 PM
alfire166's Avatar
Plug gap is 0.6-0.7mm (0.024-0.028in.). Compression is 920 kPa (133 psi). Good luck. I've got a 93 Kodiak 400 4x4 and it not bad to work on.
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Desimation2k8
Jul 17, 2015 12:37 AM
RedRancher
Jul 10, 2015 06:36 PM
