Honda RubicoN Prob...
Old Jan 22, 2001 | 08:54 PM
GabooN's Avatar
Hi
Went out on a ride with my friend tonight, we just got bout 6 inches of snow over the weekend. I was following him up this hill and I could not make it. So then I put it in low and still counldnt make it, at this point in time I was gettin worried my fried said that my front wheels were not spinning looked down and only my two back tires were spinning so I took her home since this is my 1st quad and took a look at the manual page 159 it said too check the driveshaft boots so I did and the front right boot (on the drivetain) is leaking oil and looks too be broken so I called the honda dealer and he said he never heard of this and to bring it over he said it "should" be covered under warranty I am not ruff on this thing at all and have no idea how this could of happen to it I am a big person 300 pounds 6 feet seven inches but I hope that wasn't the cause of this. This is my 1st real concern on this machine it has 675 miles and bout 100 hours on it. Has anyone ever heard of this? and what did u do too fix it if anything?
thx
-RubicoN
Old Jan 22, 2001 | 11:55 PM
TEXMud's Avatar
Many things could cause the boot to tear. Sticks are the most common. I have heard of sluch freezing around it and then tearing it. I dont know much about this being in Texas though. Is it the rubber boot that actually tore?
Old Jan 23, 2001 | 08:17 AM
GabooN's Avatar
Hi
No not the rubber but the whole boot itself looks like it torn off of the main drive shaft and oil is leaking out. It could frozen over but it hasn't been below 15 degrees here. I just hope like the guy said it will be covered under the warrantee
-RubicoN
Old Jan 23, 2001 | 09:54 AM
TEXMud's Avatar
When looking at the quad from the front. Which boot are you talking about. At the top of the drive shaft near the differential, or on the other end near the tires?
Old Jan 23, 2001 | 10:44 AM
double0griz's Avatar
Tex, did'nt you you have a drive shaft to come loose from the diff, when you first got your Rubicon, or was it somebody else?
Old Jan 23, 2001 | 11:20 AM
TEXMud's Avatar
Yes I did, this is why I am trying to help.
Old Jan 23, 2001 | 07:31 PM
GabooN's Avatar
Hi
Its at the top of the driveshaft near the differential. Would this cause me too only have two wheel drive?
Thx for your help Tex
Old Jan 23, 2001 | 08:28 PM
TEXMud's Avatar
You have the same problem I had. I noticed it after one of my first rides. That is called the inbound joint. It is held into the differential by a small "stopper ring". Basically this joint is held together by pressure. When you remove the, wheel, a-arms, hub, etc the inbound joint is actually removed with a "tug". This of course would be done when removing it for service. To put it back together you just push until it clicks into place. Not sure how many miles you rode on it like that, but it should not of caused any damage. Be sure to change the diff oil in case it got contaminated. I am not sure why this happened. I have not had one problem since I fixed this. I do periodically check BOTH of my quads for this just to be sure.
Old Jan 24, 2001 | 08:43 AM
GabooN's Avatar
Hi
I would Say I rode less then a mile when I noticed it and took it back home. I have too get it serviced again since I am past the 600 mile, 100 hours point and dont have the tools nor the know how too do what u wrote so I will let the Dealer do it for me. I just hope they wont charge me.
Thx for the help
-RubicoN
Old Jan 25, 2001 | 10:26 PM
Roar's Avatar
Keep us informed, looking to buy a Ruby, and need to know all the stuff, good and bad. With all the snow and ice my 450-s endures, it is a wonder the boots aren't shredded on a regular basis. The only one I ever holed was in Arizona, and it must of been a piece of Ironwood.
98 450-s
13700 mi
stock
blackwaters
00 Kodiak
stock
wendal
May 9, 2024 09:29 PM
rgjackson
Sep 17, 2015 11:21 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Jason Campbell
Sep 7, 2015 02:25 PM
