200x help
Old May 27, 2008 | 07:11 PM
Jud 's Avatar
Default 200x help
Okay I went out today desparate to get a ride on my sort of working and not working atc 200x I turned the fuel switch off yesterday and left it off all night but when I got on it this afternoon it took a couple of kicks but it started then I turned the fuel switch on and drove it for about 5 min stopped then stalled engine was warm and wouldnt start again. It seems like it starts easier when the fuel switch is off please any help would be wonderful. thanks
Old May 28, 2008 | 08:09 PM
SMFREY's Avatar
Default 200x help
It sounds like your carb is messed up and needs cleaned
I would look at the spark plug and check the color
or watch the exhaust while running is there a blackish cloud
I would also check when engine stops after running if you have spark
These will give you some type direction to go and figure out issue
what year is 200X
Thanks
Ray
Old May 29, 2008 | 03:24 AM
Jud 's Avatar
Default 200x help
Thanks for the help. It is a 1984 200x. It does have a slight appearance of black smoke, but not all the time.
Old May 29, 2008 | 12:25 PM
SMFREY's Avatar
Default 200x help
I would then start with the basics
Check valve adjust timing chain adjust
Check timing
You could confirm if good strong spark should be Blue
You could check ALL ignition connections clean
Then if still issue clean carb
Thanks
Ray
Old May 29, 2008 | 11:29 PM
Jud 's Avatar
Default 200x help
The thing is that the needle and float just got replaced did why would it do that when they both just got replaced. I didn't replace them they were replaced by people at a shop.
Old May 30, 2008 | 12:16 AM
SMFREY's Avatar
Default 200x help
So this was just repaired?
You Could have a small piece of dirt or Dubris in the seat
If the bike sits with the fuel valve on and engine not running does fuel run out
Also have you talked to the people at the shop that just worked on bike for their input
Possibly they missed something
Ray
Old May 31, 2008 | 12:48 PM
Jud 's Avatar
Default 200x help
It does not leak gas. When we got it back he told me that he did the best he could, and that the middle part of the srark plug would stay clean but the only part that gets slightly fouled is the outer part. (before they worked on the carb the problem was that the spark plug fouled in about 20 min of driving time.
Old Jun 3, 2008 | 12:59 PM
SMFREY's Avatar
Default 200x help
It may be time to freshup the top end
As there is a point all engines need top end done
Not a major deal
Usually disassemble top end see what is needed
If you are lucky it may just need rings and valve seals
Gaskets
Not to much then should be trouble free
Thanks
Ray
Old Jun 6, 2008 | 02:37 PM
Jud 's Avatar
Default 200x help
It already has had a top end done on it.
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
88Warrior
ATC 3-Wheelers
Aug 7, 2001 07:27 PM
hrc200x
ATC 3-Wheelers
Feb 7, 2001 08:46 PM
bigmanm
Jun 28, 2000 10:34 PM
200X
ATC 3-Wheelers
May 24, 2000 10:47 PM
