My warrior has bad low end hesitation I need help trying to fix it!!
Old May 28, 2008 | 01:27 AM
sipek08's Avatar
Default My warrior has bad low end hesitation I need help trying to fix it!!
I have a 87 yamaha warrior and from idle it has a bad hesitation. It will rev up but it cuts out when you crack the throttle. I dont understand what it could be i put two different carbs on it and a different head off my buddys bike and a different cdi box on it and adjusted the valves and timing on it and it still does the same thing. Can Somebody help me !!
Old May 28, 2008 | 01:38 AM
91Warrior357's Avatar
wut kinda spark u gettin? id say its in ur carb but i guess u elimimated that possibility
Old May 28, 2008 | 01:43 AM
sipek08's Avatar
it looks like its geting good spark but i was thinking it might be the stator. yeah i put two different carbs and different jets and it still runs the same. and it has 120 psi compression.
Old May 28, 2008 | 09:26 AM
yea, it could be a stator warriors are known for farking trashing them for some reason...lol, specially if yours is OEM bein an 87 its prolly def done by now, and 120 psi is good, and if u got a fat white/blue spark thats pretty decent, ull have to go through your wiring harness and make sure everthing else is ok , relays, connectors, main switch assembly, ign. coil could be a little worn also, theres alot things it could be, but if it was the stator it wouldnt suprise me, if u had to replace def go with Rickys stator it wud be like $160 shipped
Old May 28, 2008 | 08:33 PM
embler's Avatar
don't know about an '87, but I know on my '00, there is a rev limiter on the parking brake. if you still have the brake, then make sure its fully closed at the lever. that or you could unhook the wire coming from it. that's what I did when I remove my parking brake
Old May 29, 2008 | 12:30 AM
sipek08's Avatar
yeah thats what i think it is. but how should i check it to find out if thats whats wrong with it?
Reactant
Mar 30, 2022 02:08 AM
hueby
Nov 6, 2015 11:34 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
