Winch mount help
Old May 30, 2008 | 10:12 PM
skinnykid's Avatar
Default Winch mount help
I have a 2006 sportsman 500 HO.
I am looking for a winch mount to fit this ATV. But I have a couple different options that say they will work but look really different.
The Warn one says not recomended for plows, whats up with that? And Gorilla winches gives me 2 options and I don't know which to choose.
Can any one tell me what winch mount I need for this ATV and I will use it for a plow also.
Thanks alot for any help ya'll can give!
Old May 30, 2008 | 11:42 PM
user493's Avatar
Moto Psycho
The winch cable gets a lot of wear when you plow because of the angle, but a synthetic rope eliminates the problem that steel cables have. I used a Polaris/Warn winch on my '06 Sp 500 with a Glacier Plow and it didn't kink the cable, but on my older quad it got messed up after a few years. I've been using Warn winches for 10 years and like them but other people have their favorite brands.
Whatever winch you get, let all the cable out and rewind it under tension to avoid screwing it up later. You don't want it sliding down into a loose pile on the spool because it can get stuck in there. I hook on to my truck and winch up the driveway with the quad in gear, not neutral.
Old May 30, 2008 | 11:54 PM
skinnykid's Avatar
thanks for the info. I have a super winch. I will try to spool it real tight like you suggested, Now I just gotta find the proper mounting bracket and I will be golden.
Old May 31, 2008 | 12:05 AM
user493's Avatar
Moto Psycho
If you already have a Superwinch, just use one of their mounts.
http://www.superwinch.com/Mounting_Systems.html
Old May 31, 2008 | 06:32 AM
hobbles's Avatar
Mornin skinnykid
Look here.
http://www.kfiproducts.com/ind...=viewProd&productId=28 This kit comes with everything,
and don't forget one of these, http://www.winchsaver.com/atvwinchsaver.html It will save your cable from getting kinks in it.
Old May 31, 2008 | 11:32 AM
skinnykid's Avatar
That was a huge help guys, Thanks.
I ordered a mount. Can't wait to get it!!!
Old May 31, 2008 | 01:56 PM
user493's Avatar
Moto Psycho
Remember. Slack screws up winch cables. http://www.winchsaver.com/slack.html
Old May 31, 2008 | 01:59 PM
skinnykid's Avatar
thanks for the advice
Old May 31, 2008 | 02:08 PM
user493's Avatar
Moto Psycho
No problem Kid. That's why when you get it mounted you have to unwind THE WHOLE CABLE, wrap 3 or 4 times around the spool, and rewind the rest of it under tension to get the cable stack up straight. If you don't and it pulls down into the stack when you use it you're screwed. You could be stranded until you can jerk the cable back out. When I take my plow off for the year I have to retension the cable because it has a lot of slack in the outer layer of the spool.
Old May 31, 2008 | 03:02 PM
skinnykid's Avatar
Ok I will do that, thanks for setting me up straight.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
