250R clutch
Old Jan 23, 2001 | 02:11 AM
250Racer's Avatar
I have a TRX 250R. I want to put a new clutch in it and am wondering what to get for it. I here alot of people using CR500 spring. What year do they use and whats an advantage of that. Also what do you recommend and what seems to work best? Thanks.
TRX 250R lots of mods and extras
Old Jan 23, 2001 | 09:27 AM
mxquadracing's Avatar
Stick with the stock friction discs, clutch plates, and clutch springs. I find they work the best. Go for the aftermarket clutch basket made by Hinson, and use the HONDA '89 update kit.
Old Jan 23, 2001 | 10:22 AM
boxcars4's Avatar
What does the 89 upgrade kit give you? Also how much for a clutch basket?
Old Jan 23, 2001 | 10:37 AM
You can get the Hinson clutch basket from most after market companies like NACS, and Jame Lucky. Check your DIRT WHEELS mag for others. I like to deal with them directly. They sell somewhere around $225.00. Not cheap, but they last longer. You'll come out better in the long run. As far as the clutch update kit, I can't find my receipts. Just ask NACS if you call them. Tell them what year motor you have, and tell them you need the '89 clutch upgrade kit, or just a price. You can even call your local HONDA dealer for this one. It will give you smoother gear changing, while shifting. Good luck.
Old Jan 23, 2001 | 11:11 AM
Dill's Avatar
the 89 clutch update kits comes with a new collar, needle bearing, washer, and clutch pressure plate, as well as possibly a pushrod.
Old Jan 25, 2001 | 09:29 PM
DS650DAVE's Avatar
Might sound silly,but can you use the 89 update kit on a 86 trx?
Old Jan 26, 2001 | 01:37 AM
Dill's Avatar
yes of course, that is what it is designed for. it 'updates' the older style clutches to the 89 style clutch, hence the name '89 clutch update'
Old Jan 26, 2001 | 10:54 AM
DS650DAVE's Avatar
Thanx,Dill...I have cover off my 86 250R right now getting powder painted, so I can install it as soon as order it .Any tips?
Old Jan 26, 2001 | 11:34 AM
Dill's Avatar
its easy to do..I'd just suggest doing it while the cover is off.
just remove the old parts, and put the new ones in, if you have a manual for your R, it will assemble just like the 89 clutch.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
