Clutch kit Installation, BF 08
Old Jun 4, 2008 | 01:53 PM
NDAMUD's Avatar
Default Clutch kit Installation, BF 08
I just purchased a Highlifter Extreme super duty clutch kit and was wondering how easy the installation was. If you have any tech. tips they would be apprecitaed. Im trying to do this my self to save $$.
Old Jun 7, 2008 | 10:20 PM
MuddinMaynard's Avatar
1). Make sure you have the right puller bolt (length wise). If it doesn't bottom out, it means your tool/bolt is too short and it is for older P models. If it is Kawi's genuine tool, it should have -1429 suffix part number.
2). Drive converter nut is left-hand threaded (CW to loosen).
3). You will need a converter holder (or improvise) to prevent the converter from rotating while you are trying to turn to loosen the main nut.
4). Check/adjust belt deflection after you install all back together.
5). You may have to apply heat to loosen up the converter from the tapered end of the crank.
fordfaithful21
Dec 7, 2015 05:52 PM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
cdstang
Aug 31, 2015 07:52 AM
