secondary spring set up
Old Jun 8, 2008 | 04:30 AM
01 SCRAMBLER's Avatar
Default secondary spring set up
i just installed a dalton black and white spring on the drive clutch and a dalton black white silver on the secondary and set it at 2-2 will this change the top end speed? or is their a better setting ? is their another setting that you can set it at and be able to nail the gas and it comes out of the hole faster? i have it installed on a 01 scrambler 500 4x4 i ride trails water and some mud (not to soupy) it revs higher before the clutches grab is this normal ? thanks for all replys
Old Jun 8, 2008 | 07:07 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the primary spring (as well as the weights) stiffeness controls how high the engine revs until engagement. the stiffer the spring the more rmps it takes to over ride the weights to engage the clutch. now the secondary controls shift in and out. if you want to get there (top end)faster you need to have the spring tighter which will hold r's a little longer but will get there quicker. but by doing this you can loose top end. the reverse is true if you make it softer as you would loose low end torque. best thing to do is try it one way and if you dont like it just put it in another hole. imo.
Old Jun 8, 2008 | 09:04 AM
ftwflh's Avatar
DITTO on what stendori said.I will add that if you want more topend use the stock 1-1 setting.I prefer 2-2 for better backshifts.You shouldnt loose that much topend with 2-2 but like stated try them both.
you will get used to the engagement.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Mphillips
Jul 2, 2015 07:20 PM
