Blaster help
Old Jun 8, 2008 | 11:43 AM
SRVstrat's Avatar
Default Blaster help
recently when i rode it it keeps missing and not reving up all the way even though i give it full throttle ..... any ideas on wat it is?
Old Jun 8, 2008 | 11:50 AM
Krait's Avatar
Could be the jetting is off, causing it to miss now and then, also could be electrical, a short in the system somewhere causing it to short out now and then. Exposed wires, loose connection, something of the sort. Check your plug tip(end that goes in cylinder head) too to make sure it isn't fouling, if it is very dark, black, then its fouling and running to rich, if its white or almost white, then its running lean...both of which are carburetor related and jetting. If its tan in colour then it should be fine.
Also check your airfilter, could be a dirty filter is making it run poorly.
-Krait
Old Jun 8, 2008 | 12:01 PM
SRVstrat's Avatar
i dont think its jetting bcuz it just started doin it and i got a brand new plug so i hope its not electrical but i guess i gotta check
Old Jun 8, 2008 | 03:22 PM
Raptor450's Avatar
Broken/worn out reeds would be the first thing I would check. If you can see light through where it seals when they are supposed to be closed, they need to be replaced.
Old Jun 8, 2008 | 03:31 PM
SRVstrat's Avatar
it better not be that cuz i just paid for new v force reeds about a month ago
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
