eton rascal
Old Jun 9, 2008 | 08:36 PM
tunker2000's Avatar
Default eton rascal
My son's eton rascal 40 cc is leaking gas, I thinks it's coming from the side, not directly from carb. any ideas.
Old Jun 9, 2008 | 09:30 PM
leesumm's Avatar
Default eton rascal
gas tank? shut off valve ? , gas line ? would be my first looks and inspections. "I thinks it's coming from the side, not directly from carb. any ideas." Does not give much to go on for specifics.
Old Jun 9, 2008 | 09:35 PM
tunker2000's Avatar
Default eton rascal
it's leaking where the air cleaner meets the carb
Old Jun 9, 2008 | 09:41 PM
leesumm's Avatar
Default eton rascal
my guess without seeing would be a needle valve in the carb overflowing out the breather tube from the cleaner
Old Jun 9, 2008 | 09:43 PM
tunker2000's Avatar
Default eton rascal
how do you go about fixing that.
Old Jun 9, 2008 | 09:46 PM
Howmon's Avatar
Default eton rascal
I'd take the air cleaner off right where is bolts to the carb. I just bought a used Hi-Bird and brought it home, the carb wasn't adjusted right and when I checked the air filter there was a puddle of gasoline in it. There could be multiple causes, but get the air cleaner off first and try to see whats going on.
Old Jun 9, 2008 | 09:54 PM
leesumm's Avatar
Default eton rascal
I am not that knowledgeable on the newer carbs and injections as they are now. I am going on guessing and misguessing. I know carbs from 40 years ago which is a different animal but similar .
This to me sounds like a good start . Trial and error and deductions if you dont have a mechanic close to call.
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Jr Wagner
Aug 21, 2015 07:56 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
