98 WARRIOR STALLS IN REVERSE: NEED ADVICE
Old Jun 11, 2008 | 07:54 PM
cms10balla's Avatar
Default 98 WARRIOR STALLS IN REVERSE: NEED ADVICE
when i put my 98 warrior 350 into reverse it stalls.... do i need to replace or is there something i can cut to make it work just stop stalling?? email is :hostetler_truck@windstream.net
Old Jun 11, 2008 | 11:03 PM
TomM's Avatar
I dont think it has a rev limiter or any such thing. Does it stall when you let out the clutch or as soon as you move the lever?
Old Jun 11, 2008 | 11:06 PM
cms10balla's Avatar
as soon as i move the lever and the neutral light goes off it stalls.. but when i pull it all the way back the reverse light kicks on..i bought a new reverse lever and rod on ebay.. should i have?
Old Jun 12, 2008 | 12:29 AM
Raptor450's Avatar
Somethings up with the reverse wiring. When I had my reverse wire unhooked by the reverse shifter it stalled when put into reverse. I would check to make sure that is hooked up and is grounded good.
Old Jul 8, 2008 | 01:21 PM
54warrior's Avatar
Any luck getting this issue resolved?
Old Jul 15, 2008 | 07:47 PM
Ace_1963's Avatar
Ok...just had same problem........there is a clutch safety switch attatched to the bottom of the clutch perch on the handlebars. the wires lead down under the headlamp assembly and a wire came loose on mine.
It may be a lose wire or it may be broken at the handlebars. There is on on top of your clutch perch that only lets you run at idle when your emergency brake is on, this one is below that one, you have to roll back the rubber boot and there is a catch clip you push in and it slides out.
Try to mannually hold it in and see if it works then, if not trace the wires and check to see if they are connected.
Let me know if this helps
GOOD LUCK!
Pehter
Oct 3, 2024 11:00 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
