Superwinch operation question?
Old Jan 24, 2001 | 01:08 PM
nove's Avatar
Here is the question…… Does it matter what way (direction of pull) you run a T-1500 Superwinch? Example: I can't mount the winch with the motor housing facing the left front tire and have it centered….(tire clearance is not good) I would rather have the wire drum a bit to the left side. If I rotate the winch 180 degrees the cable now comes off the drum from the TOP.. If I unspool the wire, re-wind it in the opposite direction and move the wire tension plate to the opposite side everything is just like I want it, and doing this (winding the wire backwards) allows the wire to come off of the BOTTOM of the drum (recommended). Only difference here is that now the motor is running backwards (drum rotation)……. Will the winch work the same with out damage running it this way with the motor now being run in reverse with the load? Will the brake action be effected? Nove
Old Jan 24, 2001 | 01:23 PM
Tree Farmer's Avatar
Nove, the tension plate's location and function is critical--While I think you can do what you propose without screwing anything up, I strongly suggest you call Jack Jolly, Superwinch Customer Service Czar, at (860) 928-7787, for confirmation.
Tree Farmer
Old Jan 24, 2001 | 10:58 PM
nove's Avatar
Tree Farmer,
Thanks for the tip.
I called Superwinch and told them what I was planning to do and they said, "DON'T DO IT!"
They told me that if I must rotate the winch 180 degrees it's better to run the winch with the cable over the top of the drum rather than re-winding it in the other direction and using the motor backwards. They claim the motor is set up to be more efficient when run this way.
I decided that I wanted the cable to run from the bottom (the way it is designed to be run), so this evening I modified my mounting plate so I could use the winch the CORRECT way.
It's working great now and I don't have to worry about any damage being done.
Thanks again for you fast response to my question.
Nove
MeadowlarkFarm
Nov 27, 2019 08:40 PM
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
bigred20653
Sep 19, 2015 02:11 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
