rejetting scrambler
Old Jan 24, 2001 | 06:55 PM
scrambler84's Avatar
Hello,
I adjusted my scramblers carb, bc it was running poorly. Know it won't move barely run when i have it going, when u hit throttle it almost dies. so i put it on half throttle and it ran alot better not 100% though.
I made mix in carb more fuel, after that it ran so so for about a week. so do i need to re jet it with a bigger jet? if so can i do it? How hard is it? What is the cost? it has factory jet as far as i know. it is a 99 400 4x4
David
Old Jan 24, 2001 | 10:23 PM
scramdaddy400's Avatar
Okay before your engine siezes rejet!!!
What ya'll need to do is take the carb bottom off you know where the gas sits. You'll see a hex shape gold thing with a hole in the middle and a line indented across the top, thats your main jet.
Stock for a '99 polaris 400 is a 230 main jet its rated for temps. of 40 to 80 degrees, if your running below 40 degrees rejet.
Go with a 250 main jet it's rated for temps of 40 to 0 degrees, this should'nt cost you more than $3 to 5 bucks at your local dealer.
After you get that in say good by to hesitation.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Jan 26, 2001 | 12:50 AM
NewDSLover's Avatar
Daddy is right! Check the following things:
1 - Clean / Replace your Air Filter
(once your filter is off, is the carb intake clean? If not, clean)
2 - Your air mixture screw. Turn this in all the way, then turn out 1 1/4 turns.
3 - Main jet, did it run right the last time? Is there now a temp change, like from 80degrees to 20degrees? If so, then you better rejet or don't run it until spring or you'll be rebuilding the top end.
Note: If you limited you throttle cable to half throttle and ran it that way. Then you really need someone that has done rejetting before to help you or you'll be w/o a ride. Get some help with this.
Good Luck
Old Jan 26, 2001 | 01:08 AM
ok. last time it ran ok but little hesatation.
Got 250 jet in runs faster than a pistol at idle is there a idle screw? it what do i need to change. but it sounds like it is running ok.
Sorry i said that wrong, i put the choke on half way sorry.
please help and reply ASAP!
Thanks,
Dave
Old Jan 26, 2001 | 01:10 AM
I sounds like it is running ok but still way to fast.
Old Jan 28, 2001 | 12:09 AM
can someone please help me so it doesn't run so fast?
thanks
Old Jan 28, 2001 | 08:25 AM
The idle screw is on the side if the carb., Its that screw with the spring on it.
Turn clockwise to increase idle, turn counterclockwise to idle down.
GOOD LUCK!!!
SCRAMDADDY400
Old Jan 28, 2001 | 07:27 PM
Dazed's Avatar
Is the top of the carb tight? is there an air leak. How about around the boot that goes over the throat of the carb. Did u put greese there so it will seal better is that clamp tight? Also is you throtel Cable adjusted correctly?
Old Jan 28, 2001 | 07:41 PM
Grease can eat at the rubber, use VASELINE.
It works the same as grease, but won't eat at the rubber.
SCRAMDADDY400
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
