99 yamaha warrior trouble running
Old Jul 1, 2008 | 11:36 PM
furiouswarrior's Avatar
Default 99 yamaha warrior trouble running
hi, i am new to this and i could really use a little help. i have a 99 yamaha warrior with little work done to it jus a couple mods exuast, and air box. this last year i flipped the quad over doing about 30-40 mph, but didnt do any outter damage. the battery terminals got loose, so i bought a new battery and charged it, installed it. the quad hasnt ran for about 8 months and i tryed turning it over today and it wouldnt start at first but with the throttle opened all the way it fired up, running real rough and making a popping noise out the exuast. the motor sounded ok at high rpm's but it wouldnt idle, and was too choppy to really ride around. also when i turn the gas on (under the gas tank) the top overflow line off the carburetor leaks the fuel out, so i was curious if this could be a carb problem. when the engine was running it wasnt leaking that i noticed but the quad acted and smelled like it was flooded. if anyone has any help at all please comment.
thanks,
-Seth
Old Jul 2, 2008 | 12:10 PM
also i am curious of how many turns the outter screw on the carb should be turned from all the way screwed in tight. i think its 3, but thats just my guestimation.
Old Jul 2, 2008 | 12:31 PM
Raptor450's Avatar
You need to clean your carb. Letting it set up for 8 months with fuel in the carb has clogged up your jets. Also it wouldn't be a bad idea to replace the fuel.
Old Jul 2, 2008 | 03:53 PM
91Warrior357's Avatar
yep just drain fuel and use new fuel, and make sure to go over your carb real good with a carb cleaner sounds like your jets are a little clogged and your bowl is all gummed up
Old Jul 4, 2008 | 12:10 PM
thanks guys, appreciate
Old Jul 4, 2008 | 08:58 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
If gas is coming out of your overflow tube it sounds to me like your floats are out of adjustment or your seat on your floats has dirt in it or a gummy fuel residue from sitting and won't let your float valve needle reseat.
njrider64
Jul 4, 2017 01:40 AM
mikey426
Jun 17, 2015 03:53 PM
dano00
Oct 7, 2000 08:13 PM
PuhiStrain
Sep 9, 2000 01:36 PM
dunc_n
Aug 26, 1999 09:32 PM
