lt80 clutch
Old Jul 2, 2008 | 11:32 AM
chuckiecheese's Avatar
Default lt80 clutch
When reassembling the clutch how much hi temp grease do you use, and what type. Is regular hi temp bearing grease ok. Any recommendations? Also, if one roller is flat, do replace the bad one, or all rollers?
Old Jul 2, 2008 | 09:07 PM
onebigzj's Avatar
Default lt80 clutch
grease!!!!!!!! why? just replace all of the rollers. with reg. clutch maintenace you should never have to again.
Old Jul 4, 2008 | 10:29 AM
Default lt80 clutch
Like I asked, any recommendations for a specific type/namebrand of "lubrication" for the lt80 rollers.
Old Jul 6, 2008 | 07:36 PM
onebigzj's Avatar
Default lt80 clutch
And I asked why? Any reason you want to lube the rollers? There is no reason to lube the rollers. But if you want to use 10 w40 lol !
Old Jul 7, 2008 | 12:29 AM
YZOtis's Avatar
Default lt80 clutch
<div class="FTQUOTE"><begin quote>Originally posted by: chuckiecheese
When reassembling the clutch how much hi temp grease do you use, and what type. Is regular hi temp bearing grease ok. Any recommendations? Also, if one roller is flat, do replace the bad one, or all rollers?</end quote></div>
Figure ya found grease in there when ya took it apart so ya wondered what kind to put back in. Both of mine where full of old grease that looked like dirty clay. I put them back together clean with no grease & new rollers. No problems. Some folks put a little dab of grease on the rollers to hold them in place while assembling but in my opinion that just gives the dust & dirt something to stick to. I only replace rollers with flats on them but that's up to you. Just get used to opening the thing up and checking/cleaning the rollers & clutches.
Good Luck
Otis
Old Jul 7, 2008 | 10:15 AM
Default lt80 clutch
Others have recommended high temp grease (member LT-80). Just wanted to know, for sure, what they meant before re-assmbly. In particuar, the type and perhaps the brand that they have successfully used. No thanks for the 10w40 remark.
Old Jul 7, 2008 | 10:18 AM
Default lt80 clutch
Thanks Otis,
But what kind of grease do you just "dab"in to hold the rollers in place. Is it regular grease used to pack bearings, or white lithium, or what. A specific answer would be appreciated, as some pranksters recommended 10w40!
Old Jul 7, 2008 | 06:36 PM
onebigzj's Avatar
Default lt80 clutch
Thanks Otis,
A specific answer would be appreciated, as some pranksters recommended 10w40!</end quote></div>
you dont NEED grease. it only helps holding the rollers!!! if you read back I asked you WHY you needed grease. and you had no reply. just WHAT KIND OF GREASE. well once again you dont need it. as for a pranksters. I was asking you a question and you wouldnt answer it. Im not a prankster. I was offering you help but you didnt want to hear it. you just wanted to know what kind of grease. so when you dont read you get a smart a$$ answer. I help all I can. so if you answer a specific question you will get a specific answer. Oh and by the way 10w40 works in the tranny
buddieboy
Dec 9, 2016 05:50 PM
QuadRiders
Oct 22, 2015 04:13 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
