How to replace worn primary slide buttons ?
Old Jul 10, 2008 | 12:03 AM
thefed's Avatar
Default How to replace worn primary slide buttons ?
It was suggested that I look into these buttons as the culprit of a slight knock at idle. Anywhere I can find a good comprehensive description of how to do this? I hear it's simple....
Old Jul 10, 2008 | 12:06 AM
ftwflh's Avatar
Best bet is to take the clutch to a dealer.It takes a specail tool for the spider and a good hold down.
Old Jul 10, 2008 | 12:09 AM
thefed's Avatar
Okay. As I have never torn into a ATV tranny...I'll rephrase my question: How do I go about removing the primary clutch?[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 10, 2008 | 12:14 AM
ftwflh's Avatar
You will need a clutch puller.But it is worth the money because you will find that you will use it quite often.
Old Jul 10, 2008 | 12:25 AM
Take to dealer! Have to have clutch puller as posted above and clutch holder and spyder tool remover! Spyder torqued past 100 lbs. Plus all marks have realign to balance clutch. They shouldn't charge more than 1 hour to 1 hr and half plus parts! Buttons If I remember run about 7-8 bucks each (6 needed) That is If you bring clutch in! Still have to buy/borrow clutch puller. Good luck
slowgsxr97
Mar 18, 2022 03:40 AM
Nondem
Feb 22, 2020 12:20 PM
joeyupton
Jul 14, 2015 11:51 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
