200cc Gio Beast bogs in first
Old Jul 13, 2008 | 12:33 AM
electromaniac's Avatar
Default 200cc Gio Beast bogs in first
Hi all!
I have a 200cc Gio Beast which I've got running quite well thanks to some of the posts here. One little issue I am having is that every so often when reving through 1st gear, it bogs to almost a stall and then takes off. Can't repeat it every time, but every few hits from a stand still.
I have moved the snap ring to the 3rd (middle) position as suggested here, but it is no better (actually made little difference). I believe I have the carb tuned right as I get it to start and run pretty easily most of the time.
I've done the oil change and chain tightenning and spark-plug change to NGK as suggested here. All these things made a difference by the way. The air filter is clean.
Any ideas?
Old Jul 14, 2008 | 02:20 PM
NJDale's Avatar
Try moving the 'needle slide' up one notch (richer).
It sounds like it is getting 'too big a gulp of air'. Unfortunately, these carbs are not sophisticated enough to have an 'enrichment valve' which adjusts for this (automobile carbs).
Old Jul 14, 2008 | 02:28 PM
so that would mean move the clip down right?
Old Jul 14, 2008 | 03:00 PM
NJDale's Avatar
Yes.
Old Aug 4, 2008 | 08:05 PM
Default 200cc Gio Beast bogs in first"></title><script src=
Sorry it took so long to get back... did the clip down thing to allow a richer mix and it seems to have really made a difference. Just wanted to follow up, better late than never.
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
