Rebuilding my1986 trail boss
I am thinking of blocking off or disconnecting my oil injector and going with premix.
My existing cable starts at the lever as 1 cable then branches out to 2 (1 for throttle, 1 for oil). This cable is shot. Has anyone switched to a single throttle cable. if so what did you use?
I have seen them rick ritter at www.rittercycle.com sells the hole block off kit with the single cable
I just used the stock cable, But my oil pump was shot and not my cable. if your pump is good then I would just get a stock cable, if not then go premix (it's always good to know your getting oil) if you go premix and your current stock cable is functional then then just disconnect and let it move freely just insure it will not grab onto or stick against anything. If it grabs a hold of something you won't be able to accelerate, if it sticks against something you might not be able to decelerate, common sense I know but just putting it out their for ya'
