2003 Polaris 700 Sportsman
Old Jul 25, 2008 | 11:28 AM
roughstockrob's Avatar
Default 2003 Polaris 700 Sportsman
I just bought this machine and when I got it home it ran great. Now at an Idle it runs great, when you hit the throttle and come off idle it spits & sputters. Anybody have an Idea of what the problem could be. This ATV is new to me and I'm not familar with it. Any help would be appreciated.
Thanks
Rob
Old Jul 25, 2008 | 12:32 PM
SPORTSMAN70003's Avatar
Couple things to check is your air filter, check carb boot for cracks (boot between the carb and head) and exhaust donut gasket at the manifold. Also when mine was new I had the rubber gourmets come off the carb bracket and was letting the rubber boot separate from the back of the carb and was causing it to sputter.
Old Jul 25, 2008 | 02:02 PM
Thanks,
I'll check those tonight and let you know what happens.
Rob
Old Jul 25, 2008 | 10:31 PM
atv gooroo's Avatar
There is also an inline fuel filter that you can change too. It wouldn't hurt to find the drain screw on the bottom of the bowl on carb and let that drain a little either.
Old Jul 25, 2008 | 11:01 PM
While your at it IF still has those D**N Champion plugs,replace with NGK BKR6E. Had 02 and 03 machines that spit and sputter because of fouled Champions! Just a thought. Good Luck.
Old Jul 26, 2008 | 07:35 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does it come out of it when you get going or does it do it non stop?
Old Jul 26, 2008 | 12:00 PM
embler's Avatar
another thing is to check all the vent hoses coming from the carb. make sure they are on there and are not kinked or clogged up.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
