2005 Rancher 400 AT
Old Jul 25, 2008 | 11:39 AM
ochkev's Avatar
Default 2005 Rancher 400 AT
My esp works great, but when I put it in auto, sometimes it works, other times it doesn't. When it acts up, it is like I have the brakes on trying to move. It gets bogged down and doesn't want to go. I put it in esp, and it works fine.
Old Aug 1, 2008 | 12:10 AM
robertdpg's Avatar
I am have the same ATV, and I am having the same problem. If you find the solution let me know, and I will do the same.
Old Aug 1, 2008 | 07:16 AM
Cummins123's Avatar
My 07 Rancher AT is the same way. It wont let it go over 35 MPH.
Old Aug 1, 2008 | 01:17 PM
JeffinTD's Avatar
It sounds like it went into limp mode... Hopefully someone will post the diagnostic and reset procedure...
Old Aug 1, 2008 | 06:16 PM
IQ 600's Avatar
Try this,
1. While holding the up and down shift buttons onthe left handlebar, turn the key on / off / on. The dash should flash.
2. Now press up / down / up on the shifter, and then press the throttle to full throttle one time.
3. This is called initializing the transmission.
Let me know if this solves your problem
Old Aug 2, 2008 | 10:41 AM
HondaMechanic's Avatar
You may have to cleanup the centrifugal clutch with 220-400 waterpaper to get the bike to shift right...
Old Aug 2, 2008 | 01:12 PM
robertdpg's Avatar
I tried the transmission initializing on my Rancher 07 it did not have any effect on my problem. I have tried to retreave the error codes also the ECM is not showing any. Could the ECM be faulty? If the centrifugal cluch was bad would'nt it also malfuction in EPS mode. Thanks for any help.
Old Aug 2, 2008 | 05:09 PM
No they will shift properly in ESP .. When in Auto mode the ECM doesn't know what position to put the swash plates because if the centrifugal clutch is glazed/burnt it will cause the engine to rev higher than normal which confuses the ECM ..
Old Aug 3, 2008 | 08:48 AM
robertdpg's Avatar
Than you for your advice I will try to clean the clutch.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Brandon400
Sep 5, 2015 08:44 PM
