90cc idle question
Old Jul 26, 2008 | 12:04 AM
adr17's Avatar
Default 90cc idle question
on a sunl 90cc there is no gear shifter,, when i it starts it want to go without giving any throttle,. i dont think its supposed to do that,,, how do you adjust it so it will idle and not move? anybody have any thoughts on this?
Old Jul 30, 2008 | 04:45 AM
hotblooded's Avatar
Sounds like you have a stuck rear clutch.
Old Jul 30, 2008 | 01:02 PM
luvmysxs's Avatar
their's an idle adjustment screw on the carbuetor, it's the only screw thats sticking out, simply turn it out, (counter clockwise) until desired idle is set.
Old Jul 30, 2008 | 07:33 PM
hotblooded's Avatar
But if this hasn't been moved before there seems to be something else that changed. One problem that I have had is the large nut inside the rear clutch backs out and presses agains the housing which does not allow the rear clutch to disengage. just my output.
Old Jul 31, 2008 | 01:49 PM
real man 1's Avatar
Have a yamoto 110cc manual shift. The Carb started running rough and will not idle. I drained the tank and carb bowl & put in new gas. I only see one screw on the carb and that is on the right side and it has a spring behind it. Is this the idle screw?
I tried adjusting this screw until rpm picks up but it still will not idle. Rpm drops off and dies. I removed the trhottle cable from top of carb and checked the metering jet which looks fine. I would think the idle adjust should be a mechanicle stop like on autos. Need help...
Old Jul 31, 2008 | 02:17 PM
luvmysxs's Avatar
real man 1
yes thats the idle screw, one reason why it won't idle back down is that the thottle cable is binding somewhere, so check out the thottle cable.
hotblooded
the reason why your clutch nut is backing off is because when somebody took the clutch apart they eaither forgot to bend the retainer locking tab back, or forgot altogether to put it back on, the nut retainer is a type of washer that installs on the clutch shaft spines with tabs on it, after you torque the clutch nut then you find one of these tabs that match up to the nut cut out and bend it into the nut cutout, this preventing the nut from backing off. you need to remove the clutch cover and fix this. any other question e-mail me luvmysxs@yahoo.com
Cole Hadden
Jun 15, 2025 09:05 AM
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Firefighter400
Oct 8, 2022 06:38 PM
vlkster
Jul 28, 2015 11:35 AM
ranvette
Jul 12, 2015 06:34 AM
