questions about sportsman
Old Jul 26, 2008 | 09:11 PM
skinnykid's Avatar
Default questions about sportsman
when charing the battery do you guys charge using 6 or 12 volt from your charger?
I have some cracks in my front cargo box, I would like to seal them up, any ideas
and last, have you guys ever tried painting the plastics? I am having trouble finding a paint that will stick and not scratch of easily.
Thanks for any info
Old Jul 26, 2008 | 10:02 PM
!2 volt system, 2 amp setting if charger equipped, have had some customer use hot glue on some small cracks, but on painting some other members can give you some of their recommendations. Krylon makes a plastic paint,dont know how good it is about holding up. You should get more responses. Good luck.
Old Jul 26, 2008 | 10:15 PM
skinnykid's Avatar
12 volt 2 amp? ok I will look at my charger to see if I have that setting.
I am not sure about hot glue but I will try it I guess.
I know about that krylon stuff. I have stuf now that sposed to bond to plastic but it could be better
Old Jul 26, 2008 | 10:41 PM
Mikka's Avatar
They sell in our autoparts stores here (Canada) a product called "Goop" I had a cracked clutch cover on a trail boss and I used that stuff to seal it. Works very well. Krylon paint has a patio furniture paint for plastic. Wallmart should have it. Not sure if it comes in black though.
Mikka's Avatar
Old Jul 27, 2008 | 07:28 AM
ZAKAZIM's Avatar
I have used a 2 part mix called 40-40 to fix a crack on one of my old ATVs. I had to get it at an auto body / paint store. It was not cheep but once put on and set up (about 25 minutes) I was able to sand it down to make it blend in and it never broke after 2 years I had it.
Old Jul 27, 2008 | 08:11 AM
crazy-8's Avatar
ive used apaint called fusion on the front facia on my truck its holding up great. ive never used it on my atv but you can try it. i got mine at wal-mart for 4$ acan. i just used 400 grit to rough it up a bit then cleaned it and sprayed it.
Old Jul 27, 2008 | 05:20 PM
skinnykid's Avatar
That is what I am using now.
It is called camo, it is for outdoor hunting equipment. it still rubbed off in some spots. Maybe I will power spray the quad and then ruff it up with sand paper and try it again.
thanks for the help.
Old Jul 27, 2008 | 05:23 PM
user493's Avatar
Moto Psycho
An hour after you're done charging the battery, check the voltage again. It should be between 12.8 and 13.0. If it's less than 12.8 volts it's not fully charged. This information is off the OEM battery instruction sheet.
Old Jul 27, 2008 | 08:39 PM
Rowe's Avatar
JB Weld rough the plastic up where your putting it on too. As for paint I don't think anything really holds up well on plastic. I would read the cans recommendations and use whater primer they suggest. I still don't think your gonna get a durable finish but you never know until you try!
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
