Water Pump Seal Removal
Old Jul 29, 2008 | 11:28 AM
02magnum500's Avatar
Gets his share of deer.
Default Water Pump Seal Removal
Hi, I have a 2005 sp700 twin and it is leaking coolant out of the weep hole. It is not very much but makes a small puddle on the frame. Can I use screwdrivers and other misc tools to get the seal out and in, or do I need the polaris tools?? I know not to damage the shaft doing it. Has anyone done this without the polaris seal puller?> if so how is it done>?
Thanks!
Old Jul 29, 2008 | 11:43 AM
upnort's Avatar
I have never done it, have heard some have. Just had mine on the 800 done about a month ago cost 150$'s. While there asked how involved it was and said that if you bend the shaft the motor has to be taken apart so bit the bullet and said to do it.
Old Jul 29, 2008 | 04:25 PM
atv gooroo's Avatar
I usually do all my own work except for that job. It will cost you the same thing if you buy the tool vs letting the dealer do it. Call the dealer and make sure he has the tool for the job before you take it in and let them tear it down. I called my dealer and he said he had it but didn't and my bike stayed at the shop for a week. I would also recomend taking the plastic and what not out of the way to maybe help lower labor cost.
Old Jul 29, 2008 | 05:49 PM
Thats just it, if I could do it without the tool I would try...I have done seal replacement before on a peice of heavy equipment without proper tools. Just thought maybe it could work here as well.
Old Jul 30, 2008 | 12:19 AM
DONT do it. I Have a special puller to remove seal and tool to install. Have heard of some using small screw driver and bending in lip of seal and prying out,BUT not worth the risk of bending shaft. The boys above are right!
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
ghost civic
Jul 27, 2015 03:15 AM
Captjay
Jul 23, 2015 12:33 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
