Wanted- TAOTAO 110F rear sprocket 44-48T
Old Jul 30, 2008 | 02:00 PM
timkel's Avatar
Default Wanted- TAOTAO 110F rear sprocket 44-48T
I need to gear down a 2008 TAOTAO 110F. I see lots of sprockets on Ebay but none would fit. PM with what you have?
Old Jul 30, 2008 | 09:58 PM
djvjr's Avatar
I have a 125D. I'm changing the front sprocket from a 13 tooth to a 12 tooth. Takes about 5 minutes to remove the cover, chain and sprocket.
I ordered the new ones from http://www.buyatvsonline.com part # 400033. You need to specify in the notes section what tooth you want.
Read the below thread. It was very helpful information as was the individuals on here. Good luck..
http://forums.atvconnection.co...eadid=540723&forumid=1
Old Jul 30, 2008 | 11:14 PM
timkel's Avatar
I already have a 12T front sprocket. But I still need a larger rear in 44-48T range.
Old Oct 10, 2008 | 06:03 PM
blevinsbulldog's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: djvjr
http://forums.atvconnection.co...eadid=540723&forumid=1</end quote></div>
that says its only for the 50,70,90 & 110?????? did yours work??????????
Old Oct 10, 2008 | 07:51 PM
djvjr's Avatar
Front sprocket worked fine. Easy to change. Needed to grind down the sprocket hold down as the ends hindered the chain. 10 minutes total time.
I still want to find rear sprockets as is still geared way too high. If you find them, let me know.
Old Oct 10, 2008 | 08:20 PM
I still want to find rear sprockets as is still geared way too high. If you find them, let me know.</end quote></div>
so i wonder why it says its only for the 50,70,90, & 110
Old Oct 10, 2008 | 08:26 PM
will any of these work?
http://www.china-parts.co.uk/acatalog/Sprockets.html
http://www.scooterparts4less.com/web...arSprocket.htm
http://www.google.com/products?sourc...num=4&ct=title
mywifesquad
8
Sep 21, 2015 08:20 AM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
Dammar
Aug 26, 2015 07:12 PM
