trx200sx cluth help please???
Old Jul 31, 2008 | 04:53 PM
mustangt69's Avatar
Default trx200sx cluth help please???
i purchased an 86 trx200sx last week and got it running and the clutch slipped really bad under a load, i also noticed that it was a little noisy. When i would shut off the machine you could still hear something spinning inside the case on the right side and after a couple seconds you could hear it catch and the noise would stop. I took it apart and replaced the rear clutch(one with the plates and discs). Now when i drive it the clutch works great but it seems like its a little noisy down there still. Makes a little noise on acceleration and i can hear occasional clunks when shutting the motor off. I am tempted to try replacing the weights and springs in the primary clutch....could this be the culprit? loose cam chain?
thanks for your help
Old Aug 1, 2008 | 05:41 AM
mustangt69's Avatar
anyone? im not sure what to check next. I dunno if its related but occasionally i get a noise that sounds like a light knock, maybe a rod bearing or something but it only soes it on acceleration, hold a steady speed and you dont hear it.
Old Aug 1, 2008 | 06:39 AM
HondaMechanic's Avatar
The spinning you hear is the sprag in the centrifugal clutch .. The sprag (oneway clutch) is used for engine braking ..
riderollreck
Jan 27, 2004 08:15 PM
Blaster2fast
Oct 15, 2002 02:36 AM
DPGRDI
Aug 23, 2002 01:03 PM
bdscram1
Oct 23, 2001 12:13 AM
ctebbe
Jul 21, 2000 10:27 PM
