front brakes
Old Aug 3, 2008 | 01:24 AM
bigmo4126's Avatar
Default front brakes
im full of questions tonight, my front brakes are not working to good, i bleeded them, but when you put on the brakes going down hill i have to sqeeze as hard as i can, and the bike still keeps going, i noticed that the brakes feel spongee, do you think that my calipers need changing. 2003 ds650
Old Aug 3, 2008 | 01:29 AM
cynick's Avatar
I would start by checking the lines first. Do they seem a little worn out? Some times you have to bleed these brakes for a long time to get all the air out. Make sure all the air is out first and all the screws going to the calipers are tight. Then go from there.
Old Aug 4, 2008 | 04:42 PM
bigmo4126's Avatar
i checked the lines, i bleeded the brakes atleast ten times and there still spongee, could it be possible that my calipers are bad.
Old Aug 4, 2008 | 04:53 PM
cynick's Avatar
It is possible. We have spent hours pumping up the brakes just so you know. And it sucks. Are you getting the pressure built up at all?
Old Aug 5, 2008 | 12:50 PM
bigmo4126's Avatar
the pressure just stays the same, no matter how much i pump it up. i also noticed the other day i was coming down a steep dirt hill very slow, so i decided to lock up the front brakes just to see how they were working, and i noticed that the right front tire continued to role, the left tire locked up like it should.
Old Aug 5, 2008 | 01:42 PM
cynick's Avatar
Please don't use your front brakes when you are going down a hill. You could easily endo and really hurt yourself.
You can check your calipers but I would maybe get a better brake line also. If nothing else just incase. Bleeding takes less time but it is still a pain. I am guessing the pads are good?
Old Aug 5, 2008 | 02:34 PM
bigmo4126's Avatar
ok i will do that then, my pads are atleast 80% so thats not a worry. thanks for your help i will get those new lines today.
Old Aug 5, 2008 | 09:53 PM
1882's Avatar
Runs a Full 730 Race Build!
It could be your master cylinder, happened to me. I replaced it with one from a Hayabusa and the difference is night & day even compared to stock when new.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
carolinabomb
Jul 26, 2015 08:40 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
