Scrambler Trans Switch Issue!
Old Aug 3, 2008 | 11:26 PM
scraff33's Avatar
Default Scrambler Trans Switch Issue!
Hey Everyone,
First wanted to say that these forums are awesome when it comes to anything quad releated. I have been reading for some time now and have found tons of info.
Here is my issue....I have a 2007 Scrambler 4x4 HO 500 and I ride it hard. The problem is with the transmission switch...the switch that will not enguage the starter if not in Neutral or have the parking brake on. When I try to start from Neutral, I will need to jiggle the shifter back and forth a few times before the starter will enguage. Also, I noticed that my Neutral light will not come on...dont know if it is burned out or if it has to do with the switch issue.
Any info would be greatly appreciated!
Thanks...Scott
Old Aug 3, 2008 | 11:42 PM
Check transmission switch to see if e-clip in place and switch tab securely in notch in trans case to keep from moving. Have replaced a couple faulty switches (one had a small crack and water and mud contaminated) Also check and seal connector with elec type waterproof gel(Niogel)
Old Aug 3, 2008 | 11:48 PM
scraff33's Avatar
Thanks for the reply. Is the connector in the trans case? I have the serice manual for my machine but it does not show me where the switch is located.
Old Aug 3, 2008 | 11:52 PM
Located on right side of trans,cant miss it. Will see shaft turn inside switch as you shift lever. Good luck
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
Chocobamofo
Jul 10, 2015 07:46 PM
