has anyone tried the new 20 w 50 yamaha oil
Old Aug 4, 2008 | 07:11 AM
330's Avatar
330
Default has anyone tried the new 20 w 50 yamaha oil
i was thinking about trying it because the 660 runs so hot the owners manual calls for 20 w 40 but that was before the new oil came out any suggestions thanks
Old Aug 5, 2008 | 12:21 AM
Malachi's Avatar
I'm running the 20w-50 in my 660 grizzly. When I got the bike it didn't use a drop of oil until I changed the oil. I used Yamalube 10w-40. Then I started noticing the oil being low. About every 60 miles I'd add a half quart. So I changed the oil again and switched to Yamalube 20w-50 and haven't lost a drop since. I've put about 400 miles on it since I started using the 20w-50 and had no problems what so ever. I ride in 80-100 degree weather all the time.
Old Aug 5, 2008 | 11:55 AM
CraZySteve's Avatar
I plan on running the 20W-50 in my Quad for Spring / Summer / Fall... If I run in the winter I will put in 10W-40. Though I own a sled.. so I doubt I will use my machine in the Winter.
-Steve
Old Aug 19, 2008 | 01:35 AM
norby449's Avatar
I use it and have no complaints, I run at the dunes pretty hard in hot weather and have some engine mod's, and it was recomended by the yamaha shop and the guy who built the motor
Old Aug 25, 2008 | 09:26 AM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: norby449
I use it and have no complaints, I run at the dunes pretty hard in hot weather and have some engine mod's, and it was recomended by the yamaha shop and the guy who built the motor</end quote></div>
Norby, You definitely should be running 20W50 -- you might even want to consider Semi-Synthetic or Full-Synthetic for those temps...
Old Aug 26, 2008 | 09:21 PM
norby449's Avatar
I ran the blend and did not notice any diferance. I have never had any temp problems, and I figure the factory uses 10 /40 to test
so for the money I just run the 20/50 and change it at the end of the weekend or after 15 to 20 hrs.
Old Aug 27, 2008 | 01:46 AM
CraZySteve's Avatar
so for the money I just run the 20/50 and change it at the end of the weekend or after 15 to 20 hrs.</end quote></div>
Norby,
You won't notice much in the temp difference.... years down the road you will benefit from having run the semi blend or the full synthetic... the result is less wear on the internal engine components...
Old Aug 29, 2008 | 12:24 AM
norby449's Avatar
Thanks for your input, but for the money I will stick with the 20/50 and change it often, as I said. You are correct, but as often as I change the oil I think she will be OK.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
