SLA-110KLB transmission
Old Aug 4, 2008 | 08:01 PM
kuntryblood's Avatar
Default SLA-110KLB transmission
I just picked up an 06 sunl sla-110klb for $200 it had tranny problems,but I thought it would be an easy fix boy I wish that I would of had more time to check up on them be for I got it.It sounds like you guys have had your hands full with the sunls.When I pulled the case off that exposes the chain that goes from the starter to the transmission shaft there was no fluid in it?There was a torn gasket,but no signs that fluid has been in it what if any kind of trans fluid if any goes in there?The motor needs a tune up but runs pretty good to have been sitting for six months,the tranny will engage in all 3 gears and reverse but its like the clutch is bearly engaging, the motor had about half a quart of oil to much so I drained some out and oddly enough the tranny engaged better.Any thoughts would be great it has the semiauto tranny if that helps...
Old Aug 4, 2008 | 09:20 PM
its the case that has the stator in it..
Old Aug 5, 2008 | 12:54 PM
luvmysxs's Avatar
not suppose to be any oil in that area, if there was it would have meant you had a seal leaking. try adjusting the clutch before going any further. on the right side of the engine their's an adjustment stud with a lock nut on it, depending on the engine manufacture it may be exposed or their might be under a oval cover. if their's a cover remove it, now loosen the lock nut, take a flat tip screw driver and turn the adjustment stud counterclock wise until resistance is felt, now back off 1/8 turn. hole the stud with the screw driver while tighting the lock nut. now check if the clutch and transmission works better. if not let me know. my e-mail address is luvmysxs@yahoo.com
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
