Starting problems Scrambler - Relay Clicks starter doesn't spin just a high pitch wine
Old Aug 4, 2008 | 09:45 PM
ryker77's Avatar
Default Starting problems Scrambler - Relay Clicks starter doesn't spin just a high pitch wine
The battery is fully charged. Terminals clean. Also cleaned the starter ends. Relay clicks and I can hear a high pitch wine at the starter.
Bad starter?
Corroded power and/or ground cables preventing amp flow?
Old Aug 4, 2008 | 09:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you bypass the solnoide(relay) to see if the starter would kick over? do this so you can elimnate the solnoide as the issue. the starter may need to be cleaaned or rebuilt as well.
Old Aug 4, 2008 | 09:51 PM
ryker77's Avatar
Relay was replaced. But I will try your tip of bypassing the relay. Just for a clear tip - can I just place a jumper wire or screwdriver across the relay tips?
Old Aug 4, 2008 | 09:56 PM
If starter working,can hear whine as you say,possibly bendix sticking and not engaging flywheel. Just remove recoil cover,wiggle bendix out and check/clean replace if necessary.
Old Aug 5, 2008 | 03:00 AM
atvaddict7's Avatar
loosen up the starter spin it until it will start the motor and then tighten it up, but not too much. That will do it, have seen that on some starters before.
Old Aug 5, 2008 | 11:28 AM
ryker77's Avatar
Starter doesn't spin. I can hear the high pitch electrial type buzz. A local tech told me it was probably the starter.
Old Aug 6, 2008 | 12:56 AM
Just use test light to see if power going to starter,if is then starter bad and solenoid ok. BUT still good idea to check bendix! A little extra work,but can be bad also or locking up starter. Have seen this happen. Good luck
jayking232003
Jun 9, 2015 02:54 PM
clsharky
Jun 8, 2015 11:38 AM
kevbowe
Jun 1, 2015 01:17 AM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
