front end alignment
Old Aug 5, 2008 | 09:53 AM
Oldsman67330's Avatar
Default front end alignment
Hey all, I'm working on my 97 polaris 400 sport trying to get it to handle better on the gravel roads here as we recently have been given the opportunity to ride on the streets in some of the local towns here. It handles good at low speeds, but at higher speeds, it is very aggressive steering, nudge the bars one way or the other and it's easy to loose control of it. I've got a Honda foreman that handles nice around 35-40, but this one seems pretty touchy.
I'm wondering if I give it a little more toe out if it would help.
Old Aug 5, 2008 | 10:05 AM
jodaanja's Avatar
Yes, it should help. I can't remember the spec, but it should have a small amount of toe out. If it has any toe in, when you apply any steering, it will want to go all the way, and you will have to fight to bring it back straight. If it has too much toe out, It will want to always stay straight, and it will take a lot of effort to get it to turn.
Old Aug 5, 2008 | 10:14 AM
cool, that's what I was hoping, it's been awhile since I had any schoolin' on alignment!
Old Aug 5, 2008 | 11:43 PM
Use straight edge (1x4-2x4) align against back tire to front tire. Have someone hold bars STRAIGHT, check measurement at back and front of front tire,toe out about 3/8" at front,check other side same way. Bars must be HELD tight and straight while adjusting tie rods.
Old Aug 6, 2008 | 09:22 PM
sounds straight foreward enough...thanks
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
