wheel pointed out? what is it
Old Aug 8, 2008 | 11:33 AM
whitford_b's Avatar
Default wheel pointed out? what is it
On my 400ex my front left tire is pointed out quite a bit im worried somethin is gonna fly apart when im goin fast what would be your best geuss at the problem and my a-arms arent bent
Old Aug 8, 2008 | 11:45 AM
contentsunderpressur's Avatar
If you mean pointed like, the wheel is turned just a little, pointed then you need to check your tie rod ends. Sounds like one is damaged or out of adjustment.
Old Aug 8, 2008 | 12:09 PM
whitford_b's Avatar
ya thats probly it
Old Aug 8, 2008 | 12:37 PM
ride_2die1's Avatar
Mine did the exact thing but there was a recall on the tierods on my quad so i got them replaced free
Old Aug 8, 2008 | 12:41 PM
action450s's Avatar
Well give the whole front end a good look over. Check to make sure the wheel bearings are tight, there is no play in the tie rods for the steering, and closely inspect the A-arms and all mounting points to see if anything is damaged or bent.
The alignment could be out because one part/bearing/bushing failed or is damaged, or it could be a combination of wear in all the parts. If everything seems to be OK, you can losen the jam nuts on the tie rod ends then turn the rod to adjust the toe in, but this is uaually a last step after checking for and replacing any worn/damaged parts.
Old Aug 11, 2008 | 12:35 PM
b88miller's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ride_2die1
Mine did the exact thing but there was a recall on the tierods on my quad so i got them replaced free</end quote></div>
What year/model do you have that was covered by this recall? I have an '05 400ex that has a bent tierod (my fault) but it I could get it replaced by the dealership at no cost would surely be be a good thing for me.
Thanks
greg74
Sep 10, 2019 03:03 PM
Cantbuytime
Aug 16, 2015 09:13 PM
cody500ho
14
Aug 14, 2015 05:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
