Need help 2001 Prairie 300 backfiring
Old Aug 9, 2008 | 07:03 PM
NEPAKawi's Avatar
Default Need help 2001 Prairie 300 backfiring
Hey guys I'm a newb here, and I just traded my cousin my '75 Suzuki TS185 for his 01 Prairie 300 4X4 with only 950 miles on it! It has a very decent amount of power and does really well in my woods, but it has a slight problem, at around 3/4 throttle, it will get power, hesitate, and then backfire. It always does this even when it's warmed up, I've replaced the spark plug although the original wasn't too bad, and I gapped it correctly, I also tore out and cleaned the carb, which was pretty spotless anyway, but it still does it.
It does not have a battery right now, which won't be the case in about 2 hours as I'm gonna go get one, but I am running out of ideas and trying to go cheap and easy first, but I'm new to small engines and especially carbs. Any advice is very much appreciated, thanks in advance guys.
Old Aug 10, 2008 | 08:19 AM
bigpig750's Avatar
you may have a timing issue. that is one thing that happens or you could have a valve that is not seating properly.
Old Aug 13, 2008 | 12:44 AM
atchonda185's Avatar
You must have a battery! without the battery some type of governer kicks in and wont allow the engine to go to full power. This may be your problem. This applies to the 400 which I have. Remember that without a battery, full engine speed can damage the alternator.
Old Aug 19, 2008 | 04:11 PM
NEPAKawi's Avatar
Yes, thank you, posted on another forum and got the battery advice as well, it was the problem, I was being cheap and figured I could just pull start it, but I'm ok with a button starter too haha. Thanks guys.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
ReconBayou
Oct 16, 2019 02:24 AM
35dodge
Sep 29, 2015 09:40 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
