rear bearings
Old Aug 13, 2008 | 01:01 PM
200es's Avatar
Default rear bearings
i have a 500 scrambler 4x4, i'm trying to change the rear axle bearings but can not remove the axle nut, has anyone else ever have trouble removeing them, i tryed heating it and no luck
Old Aug 13, 2008 | 01:09 PM
atv gooroo's Avatar
What are you using to remove it; torque wrench; socket wrench; air wrench; pipe wrench?
Old Aug 13, 2008 | 01:15 PM
MECHANIKE's Avatar
IS'NT IT TWO NUTS THAT LOCK TOGATHER??
Old Aug 13, 2008 | 02:01 PM
kukerdan's Avatar
Yeah, I had the time of my life doing it, but that was the first time these things budged in years.
Best bet is to get a hold of a big adjustable wrench, that can go up to 1 7/8 at least, might even be a bit bigger.
use P Blaster, let it sink in for a while, clean the threads in front of the nut with a WIRE brush.
Put a pipe on the end of the wrench and I believe you would pull down, aka towards you once you
break the outer nut away, the other one should follow.
Do what I did when you pull the axle, and clean the heck out of those threads and splines with wd-40 and a good wire brush.
It will make subsequent removals a breeze
- Dan
Old Aug 13, 2008 | 04:44 PM
03scrambler500's Avatar
HEAT IT UP. It will come free right away then.
Old Aug 13, 2008 | 10:54 PM
For you welders out there! had a customer about 10 years ago weld an open socket inside a hollow 3' steel tube with a 1/2" impact adapter welded at the other end,I just slip it over axle and impact nuts off,sometimes have to heat,but best homemade tool we have ever bought! Paid about 40 bucks I think. He sold several to area dealerships.
Old Aug 14, 2008 | 07:53 PM
200es's Avatar
ok i got it apart, put new bearing and seals inside, when put back together it does'nt fit together right. the peice that holds the sprocket does not slide over far enough the axle can still slide about 1/4 inch even with the axle nut tight. what am i missing,???
Old Aug 14, 2008 | 11:34 PM
Is the circlip on drive shaft and collar that holds it on left side installed correctly? Cant see what you are doing,just first thing I can think of!
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
Peter_
Jul 18, 2015 07:06 AM
rcappie4
Jul 10, 2015 04:54 PM
