NGK Spark Plugs
Old Aug 13, 2008 | 10:47 PM
deerwagon's Avatar
Default NGK Spark Plugs
I was told to replace my Champions with NGK plugs... I have a 2005' 700 EFI. I was told to buy "NGK BKR6E". The NGK website says that I need "NGK BKR7E". Anyone know? AND - Is it worth it to buy the irridium plugs for twice the price? Thanks, Jeff
Old Aug 13, 2008 | 11:03 PM
JCDEYO25's Avatar
I have the same exact machine and put the NGK BKR7E in.....
John
Old Aug 13, 2008 | 11:15 PM
Can use BKR6E,but if run wfo most of the time use bKR7E which is a colder running plug.Hotter heat range Plugs ( lower number,hotter running plug) do not put out more spark,but are designed to run at a hotter temp range. Have only used high dollar iridium plugs in race bikes, plus according to specs are supposed to help electronics last longer! DONT know about that statement though!
Old Aug 13, 2008 | 11:28 PM
deerwagon's Avatar
Thanks guys, and thanks for your help earlier OPT (with my overheating issue). I ended up buying a digital ohm reader $19.99. I got some good instruction from the new dearlership. They had me fire up the machine and watch the ohm reading on the sensor on the block. I went from 1600 ohms (cold) down to 450 ohms. I unplugged the fan and only got it 300 ohms. The fan will only come on when it reaches 250-230 ohms. I replaced the sensor on the block $30. My fan kicks on right at 250 ohms. I'm sure I'm not telling you anything you don't know, but thanks again... Jeff
Old Aug 14, 2008 | 02:22 AM
deerwagon's Avatar
Believe it or not, loss of power was due to ETC cable loosened. I adjusted to the manufacture specs 1/8 - 1/16" of play. This did not affect my idle - still at around 1150 - 1200. Overheating prob fixed with a temp sensor replaced, Thanks again............Riding in the morning!!!!
CV Boot replacement - check
New NGK plugs - check
Fan working - check
Shifting hard/belt replacement - check
Shifting into park - Not solved!!!! (even when pulling hard on the spring)
Help from this site - PRICELESS!!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS.............JEFF
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
