Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Buying new ATV HELP!
Old Aug 16, 2008 | 11:56 AM
RandallSS's Avatar
Default Buying new ATV HELP!
Well i want a sport, i want trails for now i am a newbie, i will work up to track riding and other later, i do not know how to work manual but i would like to learn i am 5'4 145 pounds, i like the honda 250 but i also like the raptor, what to do my friends i want speed i want trails, and i will end up buying all sorts of tires for dunes and mudding later on i need something for now though to learn
Old Aug 16, 2008 | 12:47 PM
Krait's Avatar
Lots of great machines, but for an entry level sport, I would probably lean towards the Raptor 250. Manual clutches are no big deal at all to learn.
Old Aug 16, 2008 | 01:00 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If you need high ground clearance or ride in water/mud a lot, get the EX. For everything else, get the Raptor!!!
The one problem with the EX is that its shaft drive design limits suspension travel in the rear. Also, the stock tires are way lame and make it push in corners.
I think the Raptor can use a tire change as well, to something like Standard ITP Holeshots and that will give it a little extra ground clearance.
Old Aug 16, 2008 | 01:30 PM
RandallSS's Avatar
so raptor then, what would be another good choice and how do you even switch gears
Old Aug 16, 2008 | 03:47 PM
Krait's Avatar
Shift gears? Pull in the clutch and either push down or pull up on the shifter with your foot(for downshifting or upshifting), then let out the clutch. Its really no big deal at all.
Old Aug 16, 2008 | 08:34 PM
Red Rider
You have so much more direct control over the power with a full manual clutch! Find someone who is patient and experienced to help you get started, and you will have it down within the first hour. Remember, when going really slow you don't control the speed with the throtle, you do it with the clutch (depending on how much you engage it or not). Also, be sure you pull the clutch back in when you are coming to a stop....
slowgsxr97
Sep 8, 2015 07:33 PM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
antiguogrumete
Sep 5, 2015 03:41 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
