warrior won't idle?
Old Aug 18, 2008 | 06:11 PM
hndgnr's Avatar
Default warrior won't idle?
I cant get either one of my warriors to idle all of a sudden? they were running great. they start and idle with the choke on but as soon as I turn the choke off they stall I have cleaned one put it back on no change the other one is still apart waiting for a rebuild kit any suggestions will be apreciated thanks jerry
Old Aug 20, 2008 | 07:31 PM
taggart's Avatar
warriors are no stranger to this , firstly i would check tank and carb for contamination clean both , check your carb manifold rubber for cracks ,check the float level make sure its not too high check valve clearence , most likely your carb needs to be ultrasonic cleaned
Old Aug 26, 2008 | 07:39 AM
2Owanage's Avatar
Yes i would have to agree the rubber gasket between the carb and the head take it completely off and inspect it because it probably the problem and thats y it wont idle its sucking air form there instead of threw the carb with the fuel in the air mixture so give it a whirl
Old Aug 26, 2008 | 04:19 PM
blasterman831's Avatar
check slow jet on carb had same problem with my blaster it would nt idle i changed the slow jet and now it idles perfect
Old Aug 26, 2008 | 05:21 PM
CTATV's Avatar
idle mixture screw?
gunked up idle jet in carb?
Nosniborpapa
Sep 12, 2015 05:54 PM
Jaymc
Sep 11, 2015 07:45 AM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
