07 big bear back fireing & knockin
my carb has been actin up it will not idle unless you set the chock. when it idles with out the chock it back fires and you hear a knockin sound on the inside when it tries to idle.had some bad gas but put new gas in with seafome. runs good at speed just not at idle
if it runs with choke but not without its a dirty carb just give it a good cleaning strip it all out and use carb cleaner and a high pressure air jet to blow it all out , look through the jets to make sure they are not blocked and dont forget to clean the tank because thats where your problem began , if you have room you could fit an inline fuel filter to stop this happening again
