Polaris 90 Shifting problem
I have a 2008 Polaris 90 and cannot figure out why once the machine is warmed up it has a hard time going from the forward position to reverse??? If the machine is shut off it will move from forward to reverse no problem. I checked the manual and it said something about the indexing being bad.
What the heck is the indexing and how do i fix it???
Havent had problem you are having YET. HIGH idle can be one reason for hard shifting,might try to lower idle speed and see if helps. Just a thought,especially if shifts ok with engine off. Good luck
Thanks, will check the idle speed, my recollection was that I increased the idle to keep it from dieing so I will re-check. I was hoping someone had heard of the whole indexing thing and could comment on that....
