2001 sportsman 500 ho water pump help!
Old Aug 25, 2008 | 10:26 PM
woodyroad's Avatar
Default 2001 sportsman 500 ho water pump help!
Hi everyone,
I need help. Last weekend I was riding my 01 sportsman 500 ho when the overheat light came on. I crawled under the machine and found antifreeze coming out of weep hole. I called the dealer today about the parts and he asked me how I knew it was the waterpump i told him and he said that almost never does the impeller go bad and that I had to change the mechanical gasket and the oil gasket. This added 50.00 onto the cost. I then asked him if this is a job I can do yself and he said no you need a special tool. My question is does that mechanical gasket go bad or are screwing me and is this a job I can do myself, and if so how. Any help with this would be appreciated, that dealership doesn't have the best reputation. They also said it is 1 1/2 to two hours labor.
Thanks.
Old Aug 25, 2008 | 11:21 PM
Dealer is right,have to have special puller or shaft damage can happen.If leaking through weep hole then seal is bad(coolant leak,w/pump seal,oil leak,then oil seal( best to replace both! ABOUT right on labor. Changed several,havent had any impeller problems,except one that loosened up and spun on shaft and not circulating coolant. Good luck
Old Aug 26, 2008 | 08:32 AM
atv gooroo's Avatar
The tech pretty much said it all.
Old Aug 28, 2008 | 10:23 PM
Spdecat's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: woodyroad
Hi everyone,
Thanks.</end quote></div>
Water Pump Mechanical Seal Puller ( PN 2872105 )
Replacement T handle ( PN 2872106 ) Water Pump install kit ( PN 5131135 )
Old Aug 29, 2008 | 12:25 AM
upnort's Avatar
My last one a couple mos ago was about 140$'s
Cole Hadden
Jun 15, 2025 09:05 AM
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
maxjung
Jul 14, 2015 03:10 AM
