primary clutch
Old Aug 26, 2008 | 10:47 AM
marmon's Avatar
Default primary clutch
Going to haydays this weekend and am going to look for a primary while im there to fit a 01sportsman 500 w/ebs. What years will fit? Are these p85's or p-80's? and will newer models/ and bigger engines still fit minus the springs/weights being different?
Old Aug 26, 2008 | 07:35 PM
ftwflh's Avatar
You need a P90 clutch and any EBS primary will work with the proper spring and weights
Old Aug 26, 2008 | 10:37 PM
RticKwad's Avatar
Runs Stealth!
To piggy off of that, if I go with these 27" Mudlites pretty soon, I heard others
recommend I upgrade my primary spring as well in my clutch. What kind/color/type,
do they come with instructions for installation for us weekend mechanics?
Regards,
R'
Old Aug 26, 2008 | 10:41 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: RticKwad
Regards,
R'</end quote></div>
You can get by with just lightening up on the secondary spring tension to compensate for the bigger tires.
Old Aug 26, 2008 | 10:53 PM
RticKwad's Avatar
Runs Stealth!
Ftwflh,
How is that done exactly? Where do I educate myself on this, is there white papers
out here on the net? Is it down with removing some weights?
Regards,
R'
Old Aug 26, 2008 | 10:56 PM
ftwflh's Avatar
On the non roller secondarys you take them apart and set the spring to 1-1 from the 2-2 setting.On roller secondarys you have to change springs
you factory manual has the settings and how to do it too.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
