Forward/Reverse Selector Adjustment
Old Aug 29, 2008 | 10:02 AM
bsummers12's Avatar
Default Forward/Reverse Selector Adjustment
What is the proper way to make the adjustment on this. It's on a 2007 Honda TRX400 Rancher. Sometimes it will go into reverse and other times I have to push the yoke at the shifting forks to make it go.
Old Aug 29, 2008 | 10:49 AM
HondaMechanic's Avatar
Here is the TRX400FA/FG gearshift adjustment.. If it shifts hard or doesn't always shift I would also check the gearshift spindle where it passes thru the aluminum they will seize/corrode there ...
Old Aug 29, 2008 | 07:08 PM
bsummers12's Avatar
Thanks HondaMechanic. I wasn't sure if that was the adjustment or where the cable is secured to the frame. I will give that a try and post back with the results.
Old Sep 1, 2008 | 09:10 AM
bsummers12's Avatar
Took the cover off and sprayed down with WD 40. Closed it all back up and tested it out and all is well.
Thanks
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
Matt123
Sep 29, 2015 01:29 AM
