warrior starting issues.....
Old Aug 31, 2008 | 06:22 PM
ant7701's Avatar
Default warrior starting issues.....
I have a 2002 warrior that used to start everytime no problems. Well then is sat for a while and last week I did an oil change to get things going again. Since then....Ive noticed that it doesnt start without the choke open.
it leaks fuel from the overflow tube all the time so I removed the float and sure enough the needle was frozen. So I cleaned that out and cleaned out the main jet. Emptied the fuel tank and cleaned that out and started with a fresh tank of 93. Still.....no start.
She'll fire up If I have the choke open...and idle somewhat ok....but only with the choke open, if I close it....it stalls immediately. Its still leaking fuel a bit from the overflow tube just not asmuch.
AND....my father and I were messing around with the throttle stop screw....and we dont know if we messed up something.
Can someone help out with basic settings of that screw, maybe also air mixture adjustment? Anything else I should clean out or change to get this thing running solid. Its completely stock except for a K+N filter.
Old Sep 2, 2008 | 07:31 PM
ant7701's Avatar
anyone??? I need some advice please
Old Sep 3, 2008 | 12:01 AM
Raptor450's Avatar
Did you stand it up on the rear wheels to remove the oil plug? If so, then your float in the bottom of the carb is stuck down, letting more fuel into the carb bowl when it's already full. This explains why there is fuel running out of the overflow tube. Sometimes you can tap on the bowl and the float will unstick. Or it may have some trash stuck in the needle/seat assembly for the float that needs cleaning out. This will also give you starting issues.
Old Sep 3, 2008 | 09:04 PM
scottd's Avatar
Old Sep 4, 2008 | 08:34 PM
ant7701's Avatar
anyone know the specs of the throttle stop screw??? Thats the screw right under the choke that has the spring on it and ridged edges and can be turned by hand. I messed with it and not exactly sure where to set it.
thanks again guys!!!
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
