engine problem
Old Sep 12, 2008 | 11:18 PM
bigmo4126's Avatar
Default engine problem
please help. today i went ridding my bike was running fine, i decided to open her up on this long stright away, when i got up to fifth gear somthing blew, and a lot of oil shot out onto my right leg, can anybody tell me what could be the problem, i think i just ruined my glamis trip. also i think theres a slight knock from loosing all the oil.
Old Sep 13, 2008 | 02:22 AM
jusrlax's Avatar
Can you tell where the oil is coming from? Are you certain it was oil, and not coolant?
Old Sep 13, 2008 | 12:16 PM
bigmo4126's Avatar
im positive its oil, it soaked my boots ,pants and nerf bars, i cant tell were it came from, when it first happened i did think it was the radiator because of the sound, it sound like steam under presure when, what ever it was that blew, but when i looked down and saw the smoked and felt my leg burning i new it was oil.
Old Sep 13, 2008 | 12:57 PM
jusrlax's Avatar
When I blew my motor last December, I had a ton of coolant mixed oil coming out of my crankcase vent. Then the knocking sounds started, and I figured the motor was toast. I was right. Hopefully, you just have a hose that came loose or has a slit in it somewhere. Hard to tell what's going on until you figure out where the oil is coming from.
Old Sep 13, 2008 | 04:13 PM
bigmo4126's Avatar
i found the problem. on the top of the engine just above the spark plugs, you know that black rubber gasket, it gave out. i wonder if those screws come loose to make that gasket go out, or how often do you need to replace that gasket.
Old Sep 14, 2008 | 04:27 AM
jusrlax's Avatar
Is the leak coming from the valve cover gasket or from the head gasket? First thing I would try is to clean everything up real well with a degreaser, and then re-torque all of the bolts. Has the head ever been off?
joshuafromny
Jun 22, 2015 05:30 PM
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
