Scrambler 500 shaft output leak
Old Sep 16, 2008 | 11:21 PM
summitmuggs's Avatar
Default Scrambler 500 shaft output leak
Anyone know if the Scrambler 500 output shaft is common to leak? I have started to see a few drops of trans fluid under my quad after it sits for a while.... I think it is coming from the shaft seal on the output front shaft on the trans case. Do you have to take the trans out to change this seal if that is what is bad? Or can you just take it out the front if you take the foot brake out of the way? Or should I be looking somewhere else for a leak?
Old Sep 17, 2008 | 12:32 AM
MECHANIKE's Avatar
yeah i'd be able to do mine.you have to be easy,you can buy dye at any auto store to make sure.
Old Sep 17, 2008 | 01:31 AM
Thanks, good Idea with the dye. Do you know if that is a seal that goes out often?
Old Sep 17, 2008 | 11:49 AM
MECHANIKE's Avatar
welcome to the forum,i would have to say it depends on how much grit+ debre spins around on the shaft.
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Kenidah
Sep 7, 2015 07:50 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
