Trany Cases Leaking on Scrambler
Old Sep 19, 2008 | 12:51 AM
summitmuggs's Avatar
Default Trany Cases Leaking on Scrambler
Anyone know if the cases on the scrambler are glued or is there a seal or O ring between them??? Can you just tighten the bolts and seal up a leak. It is on the very bottom of the case right by the drain plug....I dont think it is the plug though.....any thoughts.....thanks....
Old Sep 19, 2008 | 07:56 AM
ftwflh's Avatar
THey are sealed with silicone.Are you sure the drain plug isnt dripping?
Old Sep 19, 2008 | 11:08 PM
You might check on bottom where gearcase is mounted to frame, tighten up case bolts around this area,plus check that bolt and nut that goes through bottom mount is tight. Have had them leak at this point because of vibration. Good luck.
fordfaithful21
Dec 7, 2015 05:52 PM
antiguogrumete
Sep 5, 2015 03:41 AM
WesTech
11
Aug 11, 2015 07:55 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
