1991 Trail boss 250 4x4 pull start rope will not recoil,its hung out
Old Sep 19, 2008 | 02:12 AM
captainelectric's Avatar
Default 1991 Trail boss 250 4x4 pull start rope will not recoil,its hung out
It will pull and try to crank and recover barely but eventually all the rope stays out. I took the metal outside pull cover off and all I see is the plastic piece that the rope wraps around. What is required to access and repair the rest of the recoil pull start? I am assuming the spring is bad? Any special tools needed? Can I just take the next housing cover off carefully? The elect start doesnt work either [img]i/expressions/face-icon-small-sad.gif[/img] Which is "mechanically" the easiest of the two to repair? The starter looks very difficult to access bolts. I want to get it running to see if its worth putting more money into.
thanks so much for any help or pics or advice !
Old Sep 19, 2008 | 11:15 PM
Tough recoil assy to work on,have to have in a vise to unscrew plastic housing if needed, easy to damage,PLUS a manual will be more precise. To me not as easy as the 500 recoil assembly,BUT this is just me! Other owners probably will give their suggestions
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
